weedis
- January 4, 2011
- Detroit, Michigan
- '02 XLT
i was driving in bad snow and when i pressed the brake kind of hard to try to knock a chunk of snow off the hood the abs kicked in and made the turck rumble and then stall. when i tryed to restart i got all the dash lights but no starter. also the milage now reads -------. also the fule pump is not turning on when i turn the key. i had a mechanic friend check it out with his big red hand held compter and he said it wouldnt talk with my computer and it must be a bad computer. so i went and got a computer from a junk yard and same problem. i then relized my 02 focus 2 years ago wouldnt start with all dash lights and ------- milage when someone tryd to steal it and cracked the plastic ring around the ignition. so i went and got a new column with key switched the ignition and plastic ring and still same problem.
PLEASE HELP.
PLEASE HELP.
