2003 explorer 4.0 lost power and stalled out. | Ford Explorer Forums
Bctinner
Hayden, idaho
2003 explorer 4.0
Hey everyone, I was on my way to work this morning and I pressed the gas a little harder to make it through a yellow light and I lost power and stalled out after about a half mile. When I lost power I was petal to the floor and it couldn't make it over a hump to get into a parking lot. I tried to start it again and it would just crank but not start. I got picked up and went to work and came back after about 10 hours and it started up right away, but was stumbling really bad and the more gas you applied the more it bogged down. It kinda acted like I was using carb cleaner on a vacuum leak but with a gas pedal. I checked for vacuum leaks, filter and throttle body looked clean, I pressed the strater valve on the fuel rail and the fuel pressure "looked" fine. Pulled the codes and got P0174, P2270, and P0775. This vehicle has started to stall before sitting a stop lights, basically the rps start to flutter and I tap the gas and everything is fine, or going into reverse sometimes will make it stall out. Any idea where I should look for this problem?
