2003 Explorer Switchable Power | Ford Explorer Forums
wxrman
cedar park, texas
2003 Explorer
Where can I tap into power on the 03 Explorer that is switched from the key...
The power "brick" under the hood is always powered and the fuse box under the driver's side of the dash doesn't seem to have any quick access to tapping in.
I am hooking up a scanner, so it's pretty straight forward.
Thanks,
Shawn
You can try the ignition harness....that might be more work than you're looking for though. If you go to Bulldogsecurity.com they have pretty accurate lists of what wires to tap for certain things like that.
