2003 Explorer Default Factory Code | Ford Explorer Forums
pricerj
Brownstown, MI
2003 XLT
Bought a 2003 Explorer and didn't get the wallet card. Searched the posts and couldn't find a suggestion other than a $40 trip to the dealer.
Discovered a post re; a 2002 Explorer (on another site) and it worked for my 2003. Thought I'd post here for others benefit.
The 5 digit Code is clearly listed on the security module located behind the passenger side rear trim panel. If you pop the access panel between the rear door and the window (the one with the seat belt coming out of it) the Module is easily seen with a flashlight (the Grey box with all the wires going to it!) The code is printed on the box. It looks a bit like a 5 digit part or model number and wasn't listed as a 'code' so don't be fooled.
You can then use the code to easilt reprogram your keyless entry pad as outlined in the Manual.
I like saving 40 bucks ... I REALLY liked not giving to the dealer !
What was the site that you got the info from?
That was exzctly what I was looking for.
Good Post!
02 EB 4x4
That has been discussed here on several occasions. A Search probably would have turned it up, but this site is pretty expansive. Which has it's good and it's bad points. :) Welcome to the site, both of you, by the way :bounce:
