Geologist
- October 10, 2011
- 2004 Ford Explorer EB
Hello Everyone,
The project truck is a 2004 EB Explorer 4WD.
The problem is as follows:
Start the truck and the red battery light comes on with the "Check Charging System" message.
Occasionally when you start the truck it will charge for about 5 minutes, then back to no charging.
Verified with my multi meter it is not charging so have already done the following:
1: New Alternator.
2: New Battery.
3: New 3 pin alternator connector.
4: New connector on the extra alternator pin.
5: Deleted the fusible links (all).
6: Ran new wires from 3 pin alternator connector all the way to their destinations.
7: New Positive cable.
8: Verified good connectivity of negative battery cable.
I have NOT changed the 2-Gauge wire that runs from the alternator to the battery box (ran out of money).
And the problem has not changed at all. It does the exact same thing as the day it first quit charging. Sometimes (very rarely) will charge for no more than 5 minutes, then just stops charging.
Any help with the problem would be greatly appreciated as I am now broke from replacing everything, and need this rig back on the road.
Thanks for looking.
1: New Alternator.
2: New Battery.
Thanks for looking.
