SamiAlnemri
- September 26, 2022
- Dresher
- 2014, Explorer Limited
Hi everyone, I have a 2014 ford explorer limited. lately, I started getting the charging system fault, I replaced the battery and still has the same issue. the charging system fault comes only during cold start for a few seconds causing the steering to jam. I tested the battery and alternator output using a multimeter, while the engine is off, it was reading 12.6v, when the engine starts, the voltage dropped to 11.6v, and after a few seconds I get the charging system fault, then the alternator kicks in with 14v voltage and fault disappear. and everything is normal for the rest of the day.
I tested the charging system at Autozone and everything was fine. any suggestion? could it be the alternator itself or the voltage regulator or what? appreciate your feedback if faced a similar case.
