2004 Sport Trac No Heat | Ford Explorer Forums
skidmarx
Detroit-ish Michigan
2004 Explorer Sprot Trac
New member here. I've taken a bit of a tour through this great forum and have learned a few things already but no silver bullet yet.
Winter is coming and although I can handle summer with no A/C, winter w/o heat in Michigan ain't fun. A/C has been out for three years, re-charged it once, but that only lasted about 6 weeks. Now heat does not work. Temp guage goes to normal half-way position so i don't think it's a thermostat. I've flushed the heater core with no apparent issue there. No cliking under the IP when I operate the controls so I don't think it's the blend door I've been reading about.
What would you guys suggest next?
Check your vac hoses. Some will be really small but try to check them all. Look under the hood first. I had the same prolbem.
