2004 Suggested maintenance | Ford Explorer Forums
DrkPony
Delaware County, PA
2004 Mounty Premier AWD
What is the suggested maintenance for a 2004 Mountaineer AWD V8? The mercury website and the owners manual both say slightly different things. Should the transmission fluid be changed? What transmission is in the 3rd Gen?
I'd go with the "severe" service schedule in your owner's manual. The "normal" schedule generally allows for far too long of mileage intervals for basic maintenance.
The trannies are so-called "lifetime fill", which I interpret as the life of the tranny, not the life of the vehicle. Probably one of the stupidest things that new car manufacturers have done. They've eliminated the dipstick, so the fluid needs to be pumped in thru a special fitting after removing a plug on the bottom of the tranny pan.
It can be done by a do-it-yourselfer, and there's plenty of information on how to do it in the transmissions forum. Just make sure you use genuine Mercon V fluid or suitable equivalent. Regular old Dexron/Mercon will cause shifting issues and/or premature failure.
Your tranny is a 5R55 series. There were a few suffixes after that denote the gearing, etc. but they're basically the same.
