2005 exp 4.0 flexfuel pcv valve location ? | Ford Explorer Forums
jasongt06
Virginia
2005 XLT
Can someone tell me where the pcv valve is located on an o5 exp with 4.0 flexfuel v6? Thanks
It's tricky to find, but it's on the rear of the driver's side valve cover. They now use some quick-disconnect fittings on them, so believe it or not, this once simple task now requires the use of some special tools. The quick-disconnect tools can be obtained easily enough at any auto parts store, and they're more or less self-explanatory to use.
