I am going through the exact same thing right this minute. The sticky on the home page shows how to take the center console apart. you will see two wires go to the bulb. You have to turn the build socket 90 degrees then pull it down, I used needle nose pliers. I went to the local auto parts and picked up a 37 bulb, no fit. Now I am trying to find the correct bulb number, I will be going to a different auto parts store in the morning. Good luck.
