2006 Ford Explorer 4.0 2wd V6 7 codes | Ford Explorer Forums
armie
California
08 explorer limted V8 2x4
Hey guys I have a explorer with the codes p0135 p0141 p0155 p0161 p0403 p0443 and then after a couple months I got a misfire code on cylinder number 4 p0304 what I have done so far is changed the spark plug the spark plug wire the coil pack and I've also done a compression test on the it and it has passed so for the misfire I think it's probably a bad injector or a dirty fuel filter my explorer only has 125,000 miles on it and for the other 6 codes I've changed the purge valve and the egr and the 2 02 sensors downstream (after the cat) and still have the same codes I think my ppm is messed up but I'm not sure.
