I have been reading through threads and have not found the answer I am looking for so I registered to ask
on the low valve for the a/c if I connect the pressure guage to read what it is it doesnt read anything.
yet when I depress the pin you can tell its under pressure and air/freon comes squirting out.
is my guage faulty? or is it suppose to do that
and this is with the truck turned off or on
could it be that the pin is not being depressed when the guage is attached or would I not get any presure anyways if the compresor is not working?
I feel it should read something as it is under pressure when you press teh pin down, but I could be wrong
thanks
thanks
