The only door that will lock and unlock on my explorer is the driver's side door. All the other doors will only unlock but not lock whether I use my key remote or use the door control. Any suggestions
Driver's side which door ?
Also, do you have an aftermarket starter or alarm ?
I went thru a nightmare with mine when the local shop spliced the harness for the alarm, and it corroded over time.
The switches in the door do not supply 12v power to the locks, they just ground them.
The only door that works properly is the drivers side door. The other doors will unlock but not lock with the key chain remote or the door control. I do no have an an alarm on the vehicle. All stock
The only door that works properly is the drivers side door. The other doors will unlock but not lock with the key chain remote or the door control. I do no havean an alarm on the vehicle. All stock
OK, Let's try again....................unless you have a 2 door Explorer (never heard of 2 door model in 2007), you have 2 doors on the driver's side.
My question was which one on the driver's side, front or rear ?
I assume the driver side front door locks are working.
I would pull the master switch and check the contacts.
