pjw73nh
- March 20, 2011
- 08 LTD
This is a continuation of another, older, thread that tended to creep and was a bit stale. I thought I would start fresh. If you MUST see where it came from, have a look here:
http://www.explorerforum.com/forums/showthread.php?t=352880
My exhaust manifold issue has been fixed. I still have some gas fumes in the cab under the following conditions.
1. Heater/AC is on fresh (not recirc). It goes away on recirc.
2. When first starting the car and when coming to any stop I can smell the odor of almost raw fuel coming out the dash vents.
3. It goes away after I start moving again.
4. There are no visible leaks anywhere front to back (had it on a lift, followed the lines as best I could). No indication of a leak anywhere that I could see.
5. The smell is more predominant on the passenger side of the V8 in the engine compartment.
6. The car runs fine, has no DTC codes set and is in full I/M readiness.
7. I suspect a leaky injector seal/o-ring(s).
Unless anyone has some more ideas of what I might be smelling or dealing with, what is the best way to test for a leaky injector o-ring. Bubble stuff? I don't have access to a halogen detector.
What is involved in changing the o-rings? Easy? Difficult? In between?
Thanks for any insight.
P.../NH
P.../NH
