Zombiejello
- May 10, 2022
- HINSDALE
- 2009 Explorer Eddie Bauer
Hello and good morning to all.
This just happened. As stated, driver's power window does not work, up or down, no clicking, movement or anything.
All other windows work fine.
Power and ground to switch. Power and ground into module on window motor.
This has the 8 pin connector and the auto up/down feature.
Thought it had to be the motor, so I got a N.O.S. Motorcraft WLRA-51 motor/regulator. Still doesn't work.
7 wires going to motor, I thought maybe the switch wasn't sending to all the correct wires. Tried a new switch to no avail.
No broken wires to door, everything has power/ground.
It's still got nothing.
I'm at my wits end here.
Could the "module" on the new and old motor be bad?
Rockauto had the motor/regulator, but they are now out of stock so returning/exchanging it isn't an option.
Thanks in advance for any thoughts, tips, etc....
