Hey all,
Just picked up a V6 Mountie, with the class II, and have some questions - I did search these forums, but couldn't find answers to these specific questions...thanks for your help ahead of time!
1) The V6 came with the class II setup. I understand that the class III towing package was also an option on this vehicle, and besides the hitch, it came with a different axle ratio. Any other differences? My question is, if I install a class III hitch with my current setup, what is the max recommended towing capacity? Does it increase to 5000 lbs, from the 3500, even without the axle ratio(might be wrong term for that) change? Or is it somewhere in between?
2) I bought a 2011 Jayco 184, with a dry weight of 2700 lbs, max weight 3500 lbs...should I install an auxiliary transmission oil cooler on this setup, or will this vehicle handle that appropriately??
Any other thoughts on this setup?
Thanks!
Thanks!
