Brian1
- February 2, 2000
- Albuquerque, NM
- 1991 XLT
- Callsign
- KG5BAQ
2010 Lincoln Navigator (Same as Expedition) Where is the electronic turn signal flasher?? The owners manual doesn't help and Google has failed so far. It is not in the under hood fuse block and it is not in the passenger kick panel fuse block. I have torn apart the lower dash around the steering column and searched under it for something that looks like the square relay that the replacement flasher is but I can not find it! It is really dumb that Ford hid the Flasher in a place that is not very obvious or easy to service.
The problem I am trying to track down is a rapid flash on the right signal and all the bulbs check out so I'm hoping the Electronic Flasher is the culprit but I need to find it.
