2010 Sport Trac default programming code location | Ford Explorer Forums
jehowe
Location
06279
Willington
2010 Sport Trac Limited
New (to me) 2010 Explorer Sport Trac Limited came to me without glove-box card with the default programming code. Anyone know where or how to find the code?
You can use the pattern, or its also printed on the back of the fuse box on an 07. I heard they quit doing that in the latter years though.
What do you mean by "use the pattern"?
Do a search, there is a combination of button presses you can use that will eventual give you the code. If I remember right you need a fob to reset it between each line of the code. Takes about 10 minutes to go through all of them if I remember right.
