2011 explore tire size | Ford Explorer Forums
dpowers
oceanside ny
2011 ford exlpore limeted
hi I was wondering if any one would know if I would be able to fit a set of
275 55 r20 of a set of stock 20" limited rims?
and if they would fit in the wheel well of a 2011 explore limited?
the rims currently have 255 50 R20 on them.
thanks for any help:)
Regardless if they would fit, I would not run those if I were you. There is a 6% difference in aspect ratio between stock size and the larger tires. Your speedo, fuel economy and braking distance may all be affected. Typically you want less than a 2% difference.
You'll have some tire bulge for sure. I ran a 275 on an 8 inch rim for awhile on my old mustang. It worked fine, just bulgy looking.
