vsuarez82
- August 12, 2024
- Richardson, Tx
- 2011 explorer xlt
2011 explorer 3.5 with 240k miles. I had no issues until I decided to change the coolant. Drained from the radiator, filled it up at the reservoir and burped it about 10 times. Now it's been a week and in the mornings when it's not hot, I can make it to work no problem and no overheating, but when I park it the hoses are full with pressure, I turn the heater on and the pressure goes down. After work and over 100 degrees. I can make it a few miles until it over heats. Or I crank on the heater and the temp goes down and I make it home. Yesterday I replaced the thermostat and still the same problem. Every time I turn on the ac the pressure builds up and starts to overheat, with the heater on its fine. Any suggestions.
