Item Wire Color Polarity Wire Location
12 Volts green/red (15A) + ignition sw, blk 7 pin plug, pin 4 or start/stop sw, blk 6 pin plug, pin 4
Second 12 Volts yellow/orange (30A) + trailer brake pre-wiring, gray 6 pin plug, pin 1
The trailer brake pre-wiring is behind the hood release.
Starter blue/white (without Intelligent Access) + ignition switch, black 7 pin plug, pin 7
Second Starter blue/white (with Intelligent Access) + start/stop switch, black 6 pin plug, pin 1
Ignition white/orange + ignition switch, black 7 pin plug, pin 1
On vehicles with Intelligent Access, use purple/orange (+) (for ignition sense only) at the BCM, gray 10 pin plug (E), pin 10. The BCM (Body Control Module) is the dash fuse box, under the driver dash.
Second Ignition N/A
Third Ignition N/A
Accessory purple/green + ignition switch, black 7 pin plug, pin 6
Second Accessory N/A
Third Accessory N/A
Keysense blue/gray (without Intelligent Access) + ignition switch, black 7 pin plug, pin 5
Data Bus yel/org (TX), pur/red (RX)(w/o Intelligent Access) data PATS Transceiver, black 4 pin plug, pins 3 and 4
The PATS (Passive Anti-Theft System) Transceiver is around the ignition switch. The PATS ignition is purple/orange in pin 1, and ground is black/blue in pin 2.
Can Bus High gray/orange (MS CAN); white/blue (HS CAN) data data link connector, black 16 pin plug, pins 3 and 6
Can Bus Low purple/orange (MS CAN); white (HS CAN) data data link connector, black 16 pin plug, pins 11 and 14
Can Bus Sw N/A
Power Lock blue/green - driver kick or BCM, black 26 pin plug (C), pin 6
Power Unlock yellow/purple - driver kick or BCM, black 26 pin plug (C), pin 8
Lock Motor gray/brown 5 wire driver kick, door harness
Driver Unlock Motor blue/green 5 wire driver kick, door harness
Passenger Unlock Motor purple/gray 5 wire driver kick, harness to rear
Parking Lights (-) (HS CAN)
Parking Lights (+) yellow/blue + BCM, gray 10 pin plug (E), pin 6
Hazards brown/yellow - BCM, black 52 pin plug (B), pin 32
Turn Signal (Left) blue/green (F); gray/blue (R) + BCM, brown 26 pin plug (F), pin 8; black 26 pin plug (C), pin 14
Turn Signal (Right) yellow/purple (F); brown/white (R) + BCM, brown 26 pin plug (F), pin 7; black 26 pin plug (C), pin 15
Headlight brown/blue (L); blue/green (R) + BCM, gray 10 pin plug (E), pins 2 and 1
AutoLights
Reverse Light blue/white + driver kick or BCM, black 32 pin plug (D), pin 13
Left Front Door Trigger green/purple - N.C. driver kick or BCM, black 26 pin plug (C), pin 9
Right Front Door Trigger white - N.C. driver kick or BCM, black 26 pin plug (C), pin 5
Left Rear Door Trigger green - N.C. driver kick or BCM, black 26 pin plug (C), pin 20
Right Rear Door Trigger yellow - N.C. driver kick or BCM, black 26 pin plug (C), pin 21
Dome Supervision gray/purple (dome lamp); purple (puddle lamp) + BCM, gray 12 pin plug (A), pin 1; black 26 pin plug (C), pin 1
Trunk/Hatch Pin gray/orange - N.C. driver kick or BCM, black 26 pin plug (C), pin 19
Rear Glass Pin N/A
Hood Pin blue/orange - N.C. BCM, brown 26 pin plug (F), pin 2
Trunk/Hatch Release brown (rear handle switch) - driver kick or BCM, black 26 pin plug (C), pin 23
The BCM (Body Control Module) is the dash fuse box, under the driver dash. On vehicles with power liftgate, the open/close wire is gray/yellow (-) at the power liftgate release switch, black 8 pin plug, pin 7.
Trunk Release Motor green/brown 5 wire driver kick, harness to rear
Fuel Door Release N/A
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm factory remote only (To disarm with out the factory remote pulse the Ignition and the Bypass at the same time)
Disarm No Unlock Transponder and ignition
Trunk Alarm Shunt N/A
Tachometer grn/blu, gry/yel, pur/gry, yel/org, brn, or grn/wh ac any fuel injector, 2 pin plug, pin 1
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal N/A
Fuel Pump purple/green + driver kick, harness to rear
Rear Defroster white/orange - latched junction connector below BCM, white 59 pin plug, pin 14
Mirror Defroster same as rear defroster
Left Front Heated Seat (MS CAN)
Right Front Heated Seat (MS CAN)
Speed Sense yellow/orange ac Powertrain Control Module, black 50 pin plug, pin 25
The Powertrain Control Module is in the engine compartment, on the passenger firewall.
Brake Wire blue/orange + trailer brake pre-wiring, gray 6 pin plug, pin 2
Parking Brake white/purple - parking brake switch or BCM, black 26 pin plug (C), pin 7
Horn Trigger purple/green - horn switch or BCM, black 52 pin plug (B), pin 33
Wipers (LIN bus)
Left Front Window (Up/Down) blue/gray - yellow/purple (base models only) A master window switch, 4 pin plug, pins 4 and 2
Right Front Window (Up/Down) white/orange - purple (base models only) A passenger window switch, 8 pin plug, pins 4 and 8
Left Rear Window (Up/Down) green/purple - brown A left rear window switch, 8 pin plug, pins 4 and 8
Right Rear Window (Up/Down) white/purple - gray A right rear window switch, 8 pin plug, pins 4 and 8
Sun Roof (Open/Close) pur/wht - pur/brn (function with ignition on only) - sun roof switch, gray 12 pin plug, pins 6 and 8
Sun Roof (Limit/Close) N/A
Memory Seat 1 purple/red - driver kick, door harness
Memory Seat 2 yellow - driver kick, door harness
Memory Seat 3 gray/purple - driver kick, door harness
Radio 12V gray/red + radio, 24 pin plug, pin 1
Radio Ground black/blue - radio, 24 pin plug, pin 13
Radio Ignition (Infotainment CAN)
Radio Illumination (Infotainment CAN)
Factory Amp Turn-on purple/red + radio, black 26 pin plug, pin 18
Power Antenna blue + radio, 24 pin plug, pin 2
Left Front Speaker (+/-) white - white/brown or green/orange - gray/orange +,- radio, 24 pin plug, pins 22 and 10
The preamp output wires are green - gray at the radio, 24 pin plug, pins 20 and 8 (Premium Plus Audio), or 24 pin plug, pins 22 and 10 (Sony Sound). If equipped, the amplifier is in the right rear quarter panel. On vehicles with amplifier, the speaker wires are white - white/brown at the amplifier, black 8 pin plug, pins 1 and 2 (Premium Plus Audio), or 16 pin plug, pins 2 and 10 (Sony Sound). The tweeter wires are green/orange - gray/orange at the amplifier, 16 pin plug, pins 3 and 11 (Sony Sound).
Right Front Speaker (+/-) white/purple - white/orange or purple/org - yel/og +,- radio, 24 pin plug, pins 23 and 11
The preamp output wires are purple - yellow at the radio, black 26 pin plug, pins 4 and 17 (Premium Plus Audio), or 24 pin plug, pins 23 and 11 (Sony Sound). If equipped, the amplifier is in the right rear quarter panel. On vehicles with amplifier, the speaker wires are white/purple - white/orange at the amplifier, black 8 pin plug, pins 3 and 4 (Premium Plus Audio), or 16 pin plug, pins 6 and 14 (Sony Sound). The tweeter wires are purple/orange - yellow/orange at the amplifier, 16 pin plug, pins 7 and 15 (Sony Sound).
Left Rear Speaker (+/-) white/green - brown/yellow +,- radio, 24 pin plug, pins 21 and 9
If equipped, the amplifier is in the right rear quarter panel. On vehicles with amplifier, the speaker wires are white/green - brown/yellow at the amplifier, 16 pin plug, pins 4 and 12 (Sony Sound). The tweeter wires are green/brown - gray/brown at the amplifier, 16 pin plug, pins 5 and 13 (Sony Sound).
Right Rear Speaker (+/-) brown/white - brown/blue +,- radio, 24 pin plug, pins 24 and 12
If equipped, the amplifier is in the right rear quarter panel. On vehicles with amplifier, the speaker wires are brown/white - brown/blue at the amplifier, 16 pin plug, pins 8 and 16 (Sony Sound). The tweeter wires are green/brown - gray/brown at the amplifier, 16 pin plug, pins 5 and 13 (Sony Sound).
Center Channel (+/-) green - gray/yellow (Sony Sound) +,- amplifier, 16 pin plug, pins 1 and 9
Subwoofer (+/-) green/pur - gry (1); purple - yel (2) (Sony Sound) +,- amplifier, gray 16 pin plug, pins 1 and 9; 2 and 10
Aux. Audio Input Left (+/-) blue - white/green (without SYNC) +,- radio, 24 pin plug, pins 17 and 6
On vehicles with SYNC, they are blue - yellow/green at the APIM, black 54 pin plug, pins 10 and 11. The APIM (Accessory Protocol Interface Module) is in the center of the dash, connected to the display.
Aux. Audio Input Right (+/-) blue/green - white/green (without SYNC) +,- radio, 24 pin plug, pins 18 and 6
On vehicles with SYNC, they are blue/green - white/green at the APIM, black 54 pin plug, pins 28 and 29. The APIM (Accessory Protocol Interface Module) is in the center of the dash, connected to the display.
RSE Video (+/-) wht/grn - brn/pur (camera); blu/wh - grn/blu (aux) +,- APIM, black 54 pin plug, pins 14 and 15; 34 and 35
RSE Audio Left (+/-) blue - gray/orange (SYNC audio) +,- radio, black 26 pin plug, pins 12 and 25
RSE Audio Right (+/-) purple/green - brown/white (SYNC audio) +,- radio, black 26 pin plug, pins 13 and 26
