Mattax
- June 16, 2011
- Fishersville, VA
- 2011 Explorer XLT
2011 Ford Explorer.
Am changing out the front and rear sway bars, bushings and end links and cannot find a video on the front sway bar bushings and rear sway bar. I found plenty of videos on the end links.
Torque Settings:
Front:
Tools:
Sockets and wrenchs: 7mm, 10mm, 17mm, 22mm
I have all the OEM replacement parts, but need information on how to remove front bushings and rear bar since the bushings are made into the bar.
I'll assume it is best to jack up the entire front end and rear end respectively when doing each bar/bushings/links. What is the best location to place the jack stands?
Above is the information I could find. If you have more information, would be appreciated.
Any help? Thank you.
Torque Settings:
Front:
Ford Explorer Stabilizer Bar brackets Torque Spec : 52 ft-lbs
Ford Explorer Stabilizer Endlinks Torque Spec : 18 ft-lbs
Rear:Ford Explorer Rear Stabilizer to Frame Bolts Torque Spec : 41 ft-lbs
Ford Explorer Rear Stabilizer Endlinks Torque Specs : 22 ft-lbs
Tools:
