2012 door panel removal | Ford Explorer Forums
joatto
2012 Ford Explorer
have to replace passenger side mirror, if anyone can advise me on door panel removal to get to mirror bolts please help
Did you pull the small cover that sits above the main door panel to see if you can remove the mirror without having to pull the entire door panel?
If you do have to remove the entire panel, behind the grab handle for pulling the door closed, there is a small plastic cover, pull it off, there is a screw behind there.....also, behind the door handle for exiting, I believe there is also a plastic cover with a screw behind it.....the rest are clips, pull hard working your way around, then slide the door panel up and off.
I agree with you ...... that mirror is attached at the top point of the door. I see one bolt near the upper hinge and would think that the other should be behind that small black plastic panel at the window.
Welcome to the Forum joatto.:wavey:
To help members answer any future questions/concerns you may have, it would help if you showed which year and model Explorer you have in the left margin in your profile. Some answers may be affected by the particular model and year.
Good luck with the mirror replacement.
what a relieve didnt have to remove door panel, small cover removed mirror came off and re installed in about 5 minutes.
