2012 ford explorer won't start | Ford Explorer Forums
Sammykay
Casa grande az
2012 ford explorer
2012 ford explorer dead battery I charged it, went to try and start it all dash lights came on then off and car went start. Any advice would be appreciated.
If the battery is the original one, it's time for a replacement. If it has bad cells it isn't going to hold a charge much less a load on it. Also check the terminal connections (clean/reconnect/make sure they are secure).
Welcome to the Forum.:wave:
As Jason, jmr061, posted, the battery is likely defective, especially if it is the original one. Did the charger indicate a full charge?
Please complete your registration by adding the 'Required' "Trim Level" (Base, XLT, etc.) to your profile so it appears in the margin. That can be useful info to have at times. Thank you
