Mattloc
- March 17, 2024
- South Pittsburg Tennessee
- 2013 Explorer PIU
Bought a 2013 piu former fire dept unit has original factory console. purchased a radio/hvac dash face that has the rear hvac controls on the bottom that mine were lacking. hooked up the dash face, radio and front hvac function good and the rear lights and buttons function, but no air is blowing through the roof vents. All the fuses and relays are connected in the fuse box for the rear air. Still waiting for the second row hvac console controls to arrive. Will need to pull the console to hook up the 2nd row controls. Do you think this connection will activate the blower motor, or will I have to run Forscan to turn them all on? UPDATE: So, after reading some past posts and looking over my vehicle, I see no evaporator/condensate lines running underneath my vehicle, just emergency/parking brake lines on the drivers side, and from what i can see there is no compressor or blower motor behind the plastic covering on the drivers side or passenger side in the rear cargo dept. What bothers me is there are 2 relay switch's and 3 or 4 fuses installed in the fuse box to control rear hvac. Why would they be there I'm assuming from the factory, when there is no rear hvac system installed? Fuses and relays are expensive and there are plenty of other vacant spots in the box for other different models.
