JohnelP
- January 5, 2018
- bbbbbbbbbbb
- Explorer 2013
XLT 4wd
Hi,
(Did try the search feature, but the returned threads do not cover the 2011 to 2019 models).
Only when I start the car. After it moves, it does not do any more. When changing from Park position to Reverse, then to Neutral, then to Drive and also if I go back to Neutral -> Reverse and Park it has a strong jolt (short strong vibration) at every transition. Practically, every shift has the jolt. After the car moves, it is not that bad.
I did not feel anything about gear shifts problem during driving.
A search trends the solenoid pack/block as the problem, but it seems to apply to previous models, not current model. Can it be the same thing on the 2014 models?
