thinkjerm
- December 14, 2022
- West chester
- 2014, Explorer Limited
I have a 2014 Explorer that I purchase brand new and currently has about 88k miles.
Vehicle ran fine two Fridays ago while driving it four about 4 hours straight with multiple start/stops. The following Wednesday the vehicle ran fine for 2 short trips and a few start/stop cycles. Thursday a pressed the start button and all electrical worked fine but the vehicle would not crank. I was able to jump start the vehicle and as the battery was about 5 years old I decided to purchase a new battery. Installed the new battery this Monday and still no start. I charged the battery overnight just in case it wasn't fully charged from the factory. Today, I tried to start the vehicle again and it sounded stronger but still would not crank, it was more of a short burst and then power would cut off.
Currently, I can start the vehicle using jumper cables but only if the other vehicle is revved up to about 3k RPM, if the jumping vehicle is at idle I get no start.
I do have FORscan and did reset the battery management, still will not start.
At this point I'm at a lose for what to check next. I don't believe it is the starter as it starts everytime I put jumper cables on it. And I don't think it's the battery as it is brand new and when I watch the oscilloscope in FORscan the voltage is normal.
Does anyone have recommendations on where to look next? I did notice that there is a sensor that looks like an ammeter on the ground wires from the battery, would that cause a no start issue?
Some history on the vehicle - I've had numerous electrical components replaced under warranty due to motor failures so I always suspected the vehicle had major electrical issues. I've had three driver side mirrors, four passenger side mirrors, three rear hatch struts, one sunroof motor, and one sunshade motor all replaced.
Thanks for any advice.
