2016 Ford Explorer XLT Service Advance Trac | Ford Explorer Forums
johng737
Freeland PA
2016 Explorer XLT
New member here, any feedback/advice would be greatly appreciated.
I am the owner of a 2016 Ford Explorer XLT. In November, I started getting a "Service Advance Trac" error when I started the vehicle. It currently has 82,000 miles.
I took it to a Ford dealership twice, and they were "unable to duplicate" the error and assumed it went away. It returned after my visits, and I again returned to the dealership, where they reprogrammed the steering control module and said it was a communication issue. This did nothing to resolve the issue, and it resurfaced again. I was then told it was due to the battery, and replaced the battery. This did not resolve the issue. I returned to the dealership and they rewrapped the wiring bundles and greased pins. This did not resolve the issue and again it came back. I then returned and was told it was the throttle body that need to be replaced. I replaced the throttle body, but that too did not resolve the issue. Now, I am being told that it is the steering column. This is a $2200 repair and I was told "they think" this will fix the issue.
I have found that the error seems to only trigger when it is below 35 degrees and only comes on the first start of the day. Any suggestions/feedback that anyone has had similar to this? I truly appreciate any suggestions/feedback. After several contacts with Ford, they agreed to cover $1600 of the repair even though my car is out of warranty, but I am still on the hook for almost $700 for a repair they can not ensure will resolve the issue. Being the 7th repair, I am not confident this will resolve it either.
Welcome to the Forum John. :wave:
There are many threads on "Service Advance Trac" combined with other warnings. Did they search for and find any error codes? The 2016 model did have throttle body issues.
Here is one I found using the 'Search' feature in the upper right. advance trac warning
