- May 3, 2005
- Litchfield Park, AZ area...
- 2021 King Ranch 4wd 3.0T
Pics show up just fine, nice color match.
Thanks to all who posted the link to the lights on Amazon. How could Ford have missed this?Now I just have to get the paint defects fixed.
Before:
After:
WOW!! Much better. Good job.
Looks great! How dot you get to them to change? I looked from the top of the engine compartment and I cannot see how to get to them.
Any suggestions to replace the high beams, mirror lights and license plate lights as well?
They are all Yellow as well... :-(
It just looks weird at night with the while and yellow lights on the same car.
If you look at the pictures you can see the tires are turned as far as possible. There is an access cover with a push pin to hold it on in the fender well behind the lights. Remove the cover and feel for the lights by finding the wire loom that goes to it.
Hello fwrogg-Can you give a specific item number for the replacement fog lights? Are these just plain plug in? How do you like the color and brightness in person? Good match and good output? Thanks!
http://www.daytimebrightlites.com got the mirror lights and license plate lights from here. I will post pictures when I get a chance
http://www.amazon.com/gp/product/B00LNNR9GG?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
takes about 5 mins to do. the inner fender has a window you pull out to get to the bulbs.
For those considering it, install was super easy. I turned the wheel all the way to the right and was able to change both sides, although the right side would've been easier if I had simply turned the wheel to the left.Removal/Install was mostly by feel, so just remember which way you have to put the bulb harness in after you twist 90 degrees to remove it. If I remember correctly, the bottom of the harness has to be twisted counterclockwise and will face 90 degrees to the right for removal. Install is just the opposite. I know just about everyone here probably knows this, but for those that may not.....
I took a picture of what the bulb backside looks like.. i honestly was tugging at something else because it's pretty hard to see what you're looking for.....
Here are the mirror lights and license plate lights
woah those are some bright mirror lights. I didnt even know there were any on the explorer haha.. were they easy to install and replace?
