SamsonExplorer
- March 28, 2025
- Key West, FL
- 2018 Explorer PIU
2018 Ford Explorer PIU Interceptor Utility Sync 3 APIM Upgrade - PIU Sync 1 to Sync 3 conversion - 4" to 8" Screen upgrade
I've been searching all over the internet trying to solve the Ford Explorer stereo upgrade problem. This is what I have figured out so far, and I will continue to update as I learn more.
Wiring Harness- (Plug&Play 4" TO 8" Conversion Power Harness PNP For Ford SYNC1 to SYNC 3 Upgrade | eBay) As far as the wiring harness goes, I looked at a ton of different harnesses, ranging from $30 to $250 from multiple different sellers, but they all seem to be the same product, with the same connections. (Photo attached with the connections clearly labeled for reference) I went with the most affordable version @ $28 and it has multiple positive reviews. Ebay confirms it's compatible with the 2018 PIU
Sync 3 Upgrade Kit- (OEM Factory SYNC 2 to SYNC 3 3.4 Upgrade Carplay Kit Fit for Ford Sync3 1080p | eBay) I'm going with a pre-programmed Sync 3 APIM kit because I haven't been able to figure out how these are programmed for the PIU. Apparently there's an entire generation of gatekeepers out there trying to keep the programming information secret from us
Don't worry, as soon as I learn a good configuration for my PIU I will post an update in here with the As-Built information. (Also attaching pics of my factory console and steering wheel for your reference)
Bezel- (2016 - 2018 Ford Explorer OEM 8" Display Radio Climate Control Panel BEZEL ONLY | eBay) Unfortunately the barebones stripped Bezels are still going for about $200 a piece right now. You can search for a better deal but as of this post, many of the Bezels listed under the $200 range have missing/cracked climate control knobs and/or noticeable cosmetic blemishes. Keep an eye out
I should be getting most of this delivered and installed within the next 3 weeks, I'll keep y'all posted.
Here's a couple good installation videos I found for upgrading the 4.2" Sync 1 to the 8" Sync 3. Hope this helps someone!
m
@syncceduppp
m
@syncceduppp
