2018 Platinum - Multiple Error Codes | Ford Explorer Forums
Ole Ostigaard
2018 Explorer Platinum
Hi folks.
Seems like Christmas Lights started early on my 2018 Platinum (3.5L).
It all started with Error Message "Service Advance Trac". This happened one day
the temperature was below 0 (centigrades). It disappeared on the next startup.
But a few days later pretty much all other Error Messages followed:
Advance Track, Hill Start, Park Aid, Pre Collision Warning ++, not available.
Engine running rough, loss of power an so on. Check Engine Light also lit up.
Anyone experienced a similar problem?
Check out the TSB https://static.nhtsa.gov/odi/tsbs/2019/MC-10163554-0001.pdf
I had this issue on my 2019 Taurus SHO.
If you can get the codes and confirm. The part is about $70, it was like $30 back in 2020.
Get it from a Ford Dealer. Also VERY EASY to replace. There are you tube vids. Its on top of the intake manifold/ black one bolt.
