toolman4
- January 20, 2021
- Mn
- 2020 Platinum
So I spent a little time with a squirl cage fan and my windows to see if I could find the leaks. It always sounds like a window is open. On the front windows it's the inner seal on the curve of the window. That seal just does not sit tight against the window as you can see in the video when rolled all the way up. It's just not a good fit and it looks like you have to take a lot apart on the door just to replace that one. I Rode in a 21 with the tech and he agreed it was the same way for noise which was hard to believe. So not sure what to do but hide the noise with a window air deflector.
The rear one is leaking in the corner on both passenger doors where it meets the smaller window. The window rocks a bunch and must not be a good fit for the window. Any suggestions welcomed. Both seals look labor intensive to replace. I hate having them tear the doors apart because nothing ever seams to go back together very well. Could also put the window air deflectors on there too. It is still under warranty. Anybody else find anything that fixes this?
