2wd v8 lift kit? | Ford Explorer Forums
2wd v8 lift kit?
akuma3d
austin tx
98 XLT V8 explorer
Hows all?
I'm new, so, HI
anyway.... anyone know a good place to get a lift kit for my exploder, it's 2wd, i know it sounds stupid, but it'll be better than the way i have it. A friend of mine, said, that it'll be easy on mine cause i have the towing option on mine, he said it's already taller than most explorers? he was saying that i can fit some good size tires on it the way it is, but i'm not sure. anyway, just wonder if anyone out their has done this to a 2wd one before... thnx for any feed back
-akuma3d
Well since your 2wd all you need are lift spindles for the front and AAL and shackles for the rear. That will give you 3" of lift, then if you want more you can add a body lift. Welcome to the site.
Please search this site for:
torsion twist
lift spindles
warrior shackles or war153
add a leaf or addaleaf
SOA or spring over axle swap
There are a few options, depends on your budget and your goal tire size.
