J5hort
- February 25, 2018
- South Easton
- 2008 XLT
1995 Sport
Got a 1995 Explorer Sport 4.0L that I use mostly as a yard truck. Dropped Transmission a while back and cut out Y-Pipe to get access to transmission. Remove entire exhaust. Wish I saved the 3 bolt flange in front of the Cat as it looked to be specific. In any event, running with open stock headers and am planning to replace exhaust. Was thinking about headers, y-pipe and out to a cherry bomb or similar that would dump out passenger side ahead of rear wheel. No problem with emissions or regs as this is old and not used on road (too much). Budget build and am thinking of keeping stock manifolds, looking at walker y-pipe which has the original 3 bolt flange. Problem is that it will need to adapted to accommodate any after market pipe/muffler. I do not need a cat setup on this. So does anyone know of or have available an old stock flange that I can use and transition to a 2.5" pipe. Not sure if there are any other Y-pipes that can be used that have the normal 3 bolt flange (circular) that I can bolt a cherry bomb or similar up to. Open for ideas, just want to quiet this down a bit and it is only a beater, so simple and economical works best. Ideas anyone?
