3 inch tt on 2wd? | Ford Explorer Forums
3 inch tt on 2wd?
two99fiveO's
Sugarland, Texas
1999 XLT
is 3 inches too high to twist for a 2wd? i don't want to completely destroy the ride quality or break the torsion bars either. also, does warrior make 3 inch shackles. i am just trying to find a cheap and easy way to fit 32s on a 1999 2wd. will 31x10.5 fit with stock rims and suspension? no shackles or tt.
You can do a 3" TT, but it is better for more than 2" of suspension lift to get the 3" lift spindles for the front, then add up to 2" of TT for 5" of lift in front. The Warriors only come in one size for the rear, they give 1.5-2" of lift. You could add leaves to the rear to bring them up to 3 or 4". To get 5" in the rear you could do an SOA, spring over axle switch.
Keep your eyes peeled for Houston area get-togethers. Also, some of us could help you install your lift.
If you want 32s, you might as well get 33s. The lift will actually be cheaper:
3" lift spindles in front and TT
SOA in the rear.
This will give you about 5 in the front and 5.5 or so in the rear.
3" lift spindles
please explain these Alec?
There are aftermarket front spindles available for 2wds. They lift the front 3".
