koda2000
- September 2, 2011
- x
The driver's door will lock/unlock using the remote or master switch. The front passenger lock makes noise like it wants to work, but doesn't. Neither rear door will lock or unlock.
Does the '01 ST suffer from the corroded pink wire splice, like the other Gen II Explorer SUV's?
On a side note, while programming the remote, when I was done (key was still in ignition, but was in LOCK position, the dash lights came on and went off of two or three times. Then stayed off as normal. I couldn't tell if it did this just when I tried the remote. Never seen this before. Any thoughts what could cause this? Ignition switch? A relay? It should be noted that I was using a remote that was already programmed to one of my other vehicles. I don't see what difference this would make.
