31's on a 15x8 rim?? | Ford Explorer Forums
Metallic2001
charleston, sc
1994 explorer limited 4x4
I am still doing some research and I was wondering if anybody has 31's on a 15x8 rim mounted on a stock explorer with no lift? I am just wondering if it will rub b/c i heard a 15x7 wont but a 15x8 is likely....I havea 1994 4x4 4dr
You have it right, 15x7 it might not rub 15x8 its likely to.
is the lug pattern on a 94 a 5x4.5 (114.3)?
I'm running a set of 31 x 11.50's on a 92 stock - on 8.5" aluminum wheels - and they rug on full lock turns.
I am going to boost it about 2" on each end and cut away any offending sheetmetal in the front end. Should be good then.
yup
Thanks for the info...ill just go with the 15x7 with some 31 all terrains
