Devan
- April 18, 2017
- Location
- central jerz
- 01 BoostedXPLR Sport
- Callsign
- Devman
I don't know if it's so much that they're proud of their work as much as they know that there really is no aftermarket performance for the 4.0 sohc so they know that if somebody really wants that **** they'll pay that price. and you're absolutely right all said and done it would be very expensive for a motor that can very easily cook or grenade itself. However those prices are for pre-built stuff of above-average quality. If I was to build a motor myself (which I will in the near future) and only bring it to a machinist when necessary I'd probably be looking at about 1/3 of expenses. Also like I said I have decided to keep this truck V6 because of how invested I've been in the V6 setup with the s/c, dual alternator etc. but I am going to get the previous Gen 2 door sport and swap in a 4.6 DOHC or SOHC either that or an 02 4 door in full black(not 03 cuz thats when they started using electronic throttle bodys on the 4.6 in the explorer. And 01 is the previous gen body) or maybe both. The 4.6 DOHC would require converting the brake booster to a hydroboost which I have absolutely no problem with because it's fairly easy to do and my Cobra has a hydroboost setup and I like it, and I would also have to redesign the blower/evaporator housing with fiberglass or watevs and a smaller evap core because I want to keep my AC lol and for clearance of course(Ford made a prototype svt lightning bolt which was a ranger with a lightning S/C 5.4 and they ended up putting some econoline blower box and evap core housing in place of the stock stuff to keep AC and to make it fit into the engine bay with the 5.4, google the lightning bolt, ive done extensive research on this and i even emailed the writers of a few diff articles where ive seen this lightning bolt ranger, to try to get more information about what they did with the climate control, but seems like the most relevant piece of info i was able to obtain was that it was some econoline blower box setup and the pictures) and then there is also designing custom headers, anything other than that is pretty easy i think. Also it's not really necessary to put every performance part under the Sun into the 4.0 sohc for it to handle decent power. I know a teacher over at UTI has an explorer 4.0 sohc with an eaton m122 on it. Probably one of the fastest v6 4.0 sohc explorers in the quarter mile, and I think all he had at the time was much better quality cylinder head bolts. But now I think he's trying to build new cylinder heads and he also did a balance shaft delete and a couple other things but the point is he has an m122 on top of an almost stock 4.0 sohc that can handle the power, although I think he did say that he had some head gasket issues at first. First he had an M90 then both variations of the m112 and now he's got an m122 on it. Oh actually my mistake I think he does have upgraded pistons and connecting rods to. He even told me that he would let me have the top plate for our banshee intake manifolds so that I can adapt an m112 to my motor, and he said that I can check out his builds to, that was a long time ago and then some things happened and then this Corona happened but I'm still looking forward to that day. I do have a cad design for an m112 top plate for my intake manifold but something about it doesn't look right to me so I'd rather have his top plate because I know it's been on a motor with an m112 before. I have a second m112 laying around from my cobra that I plan to use.Sounds like a cool project!
On a side note:
Holy crap Super Six is proud of their work! $2000 for heads!! The shortblock is $6000!! $500 for ARP head studs!! You could build a 347 stroker for all that!
Yeah I know the SOHC can be made to make power, but after you put all that money in it and try to beef up the transmission to hold it, is it really worth it??
But if we could get more information on the Cosworth head swap that would be amazing.
