The rod modification:
Bush in small end increased to 24.0xmm
Big end reised to ford bearing size
New locking grooves where made for ford bearing
The big end with was narrowed and also a chamfer was added.
Did aslo make a oilspray hole just like ford rods got....
If I am happy with the car? Nope, it is lots quicker than a stock 2.9 24v, I out run my brothers scorpio cosworth with ease, if I pull from 1500rpm in 5th gear he can be at whatever revs he likes and he cannot keep up...
After 4000rpm the engine looses power, I've tested a few different setups, actually I was going to test another one last night but due to a fuel leak I had to cancel. But I think the main reason for lack of power is due the inlet manifold. Still the engine doesn't pull bad after 4000rpm, but I think it could pull better....
On the 4.1 engine a piston pin snapped, so I replaced the bottom end with a stock 4.0 one. But now the 4.1 bottom end have been repaired, uppgraded with a girdle, I hope to have it ready to spring. Then engine will have custom made inlet cams, a slider throttle with short runners etc...
I will make a movie soon, so you need to wait until then to see how it performes...
Cossie, I don't think the techs will tell that you got a 4.0 instead of a 2.9....
