hotrod66
- December 15, 2013
- south of france, next to spanish border, europe
- 92 explorer 4wd v6 auto
Hi, after searching for a long time I finally try my chance here.
I have a 4.0 V6 OHV in my Ford taunus coupé. The engine comes from a 93 ford explorer first gen. It's now mated to a manual gearbox and still uses EECIV management.
Here is the problem: I never had the explorer on the road neither started it before removing the engine to install it in the Taunus. Since that, the engine never ran well. It start fines, drives fine but if I want the original power I need to cut out the ignition with the key and switch it on back and for around 1 minute I can put full throttle and have the full power. After this time, the engine become again a smooth but powerless engine. I tested the exhaust gaz and I have too many oxygen (O2) good Co, not enough CO2 and too much HC coming out the exhaust:
at idle:
O2: between 4 to 7.5%
CO: between 0.45 to 0.60%
CO2: between 9.5 to 12.5%
HC: between 500 to 750!!!
at full throttle:
O2: between 15 to 15.5%
CO: between 0.15 to 0.30%
CO2: between 2.5 to 3.5%
HC: between 900 to 1900!!!
I was thinking about a fuel pressure regulator problem but I have changed it and it's the same. Now I think about Lambda sensors or manifold temperature sensor...
Do you have any idea or did it happen to somebody here?
thanks for you help and ideas
at idle:
at full throttle:
