4.0 SOHC was jerking at 55-60 mph , now stalling every 2-3 miles. | Page 7 | Ford Explorer Forums
It could be crank sensor if you are just losing spark
Could be pcm rely if you lose whole engine and fuel pump
Hi 410 fortune , happy Easter. I want to replace pice of crank sensor wire the part which go behind alternator. What should I remove to get tthere? Thanks in advance. Max
hi guys. Need some help here.have 2 door sport 2001 4.0 SOHC . More details: new motorcraft fuel pump installed 3 years ago ( got whole unit from ra ), fuel filter replaced maybe 7 k ago. Got 2 sets of injectors trued them both to eliminate jerking. I did timing job and I guess it started jerking after that. Since I put set of injections from eBay when put everything back finishing timing job, I suspected them could cause jerking ( it starts at 50-55 and if I move my feet from accelerator and gently push it again it goes away. Same with when it runs on cruise control- pushing brakes and gently accelerating will fixes the issue. It’s not jerking on low speed. Starting at 50-55 . Now I have additional problem . It stalling in a few miles. Could stall while idling couple of times a months. Any idea what could be causing that ? You guys always helping Me out when I mess up) respectfully . Max in Houston
Is the issue present when OD (overdrive) is ON as well as OFF?
Remove alternator and alternator bracket
So the belt, tensioner alternator fan clutch and then you should have access to that wire
