4.6 high idle issue | Ford Explorer Forums
4.6 high idle issue
Buckhannon,WVa
2002 Eddie Bauer Exlorer
Having a head scratcher,
2002 4.6l has 178k miles
Intake is 2-3 years old and idle control valve and throttle position sensors 1 1/2 years old
Car has been idling at 3,000 RPM's
I changed out the idle air control valve with no luck (I've replaced 3 and it's always been the issue), so I returned the part.
So, I changed out the throttle position sensor, still no luck, its idling at 2,000 rpm now.
Found a small vacuum leak and took care of that issue with still no luck.
Zero cel codes until I start unplugging stuff.
So I reset the VATS? Either way... I unhooked both terminals and hooked a small wire to each and let it set 5 min and it's fine, drove it to relearn the trans and such and so far no issues.
Did you buy a cheap AutoZone idle air control valve or a motorcraft one.
Reading reviews anyone who buys the cheap one realizes it doesn't work
