4-pin trailer adapter replacement | Ford Explorer Forums
cal10
I have a 2000 Explorer and my 4-pin adapter is corroded. Is there an easy way to just replace the corroded head? Sorry if this is obvious (I'm a novice).
You already have a wire harness on your truck right?
If you do you can just cut the old adapter off and soder on the new one.
Did i answer your question?
I mean do you already have the wire harness?
You can also just buy the adapters from your local autoparts stores too.
"OH YEA WELCOME TO THE FORUM"
