4 wheel drive noise | Ford Explorer Forums
4 wheel drive noise
rifleman69
Urbandale
2001 Sport Trac
I have an annoying and somewhat loud noise coming from my 2001 sport trac. It is somewhat like a gear or grinding noise, peculiar thing is that it only comes on while in 4 wheel drive. Once 4x4 disengages noise goes away.
I am thinking front differential bearing or somthing in the transfer case but could use some help to diagnose it.
thanks in advance for your help.
Our 4x4's are live axles, meaning everything in the front spins all the way back to the transfer case whether you have the 4x4 on or off.
Make sure your tires are all the right size and that the circumference is less then 1/4 inch difference or you will cause tranfer case issues. Just say you have 2 Goodyears on the front and 2 BFG on the rear could cause a issue and noise like you are experiencing.
