gfyracing
- July 13, 2016
- Moncton, NB
- 2002 Ford Explorer ST
4 wheel drive is not engaging on my truck. When I turn the dash selector to 4 hi or 4 low, with it in neutral or park and my foot on the brake, nothing happens. I don't get any clicking from the 4x4 control module and no lights flash on the dash. When I start the truck both the 4 hi and 4 low lights come on for a split second then go out. We have had periods of -20 here lately and I have had battery issues. I have heard this can cause the 4x4 module to fry but from what I have read the 4x4 lights both shouldn't flash when the truck is started if the module is fried. I've tested all my fuses and they seem good so I believe the 4x4 module is the culprit. I find power coming into the module but when I test the 2 middle wires going to the switch there is no power to them. I know the switch is a resistor so I am assuming that those wires should have enough voltage to light up a test light. If there is no power in those wires would it indicate an issue with the control module? I know there are a lot of posts about this issue and I have read through countless ones but I don't see any that mention both 4x4 lights flashing on startup.
Thanks.
Thanks.
