4 wheel drive | Ford Explorer Forums
4 wheel drive
FordSploderXLT
West Des Moines, Iowa
95 XLT and 97 XLT V8
Yesterday I went to go use my 4wd to play in the mud, and much to my surprise, when I flipped the switch to go from 2wd to 4 auto, the 4wd lights started to flash....I had no 4wd. First thing I did was check fuses....the only one that was blown was the one for Reverse lights, DRL System, Overdrive, and 4wd.....So I put a new fuse in, and tried it again.....4wd and everything else worked fine for a few minutes....then I had no 4wd or reverse lights.... I tried checking every wire that I could to see if one was shorting out somewhere.....but I found nothing....Im completely lost on this one....can anyone help?
