40mm 96 Limited Front Sway Bar | Ford Explorer Forums
MikeTEC
Central Texas
2004 Mountaineer 4.6L
Greetings, Folks!
Planning to upgrade my stock front and rear sway bar bushings on my 96 5.0 Limited 2wd with polys. The rear bar measures 18mm and the front measures a whooping 40mm! Most poly bushings in kits measure 36mm for the front, which would be too small or would it? I am guessing the larger size is due to its being a 5.0 V-8.
Anyone with a 96-97 5.0 Limited switched to poly bushings for their stock sway bars and located a kit for a 40mm front bar? Thanks Mike
Nope, the wopping size has to do with the fact that it is hollow. You got the same swaybar that a 2WD, V6 Sport would get. Ford upgraded the swaybar to a solid bar in '98 that is of a smaller diameter than the '95-'97. The advantage being that it is solid. I'm not sure what kit you are looking at. I bought the poly swaybar bushing kit from Performance Accessories a couple of years ago and the bushings fit my huge (hollow) swaybar easily.
I would recommend changing both sway bars to beefier ones ( splid for the front ) as well as the poly vushings.
You will be amazed in the difference.
Poly bushings are available from Explorer Express as well as other places.
Good luck.....
I cought some flack for kind of absent mindedly passing by Hank's product. I believe he sells poly bushings. Might give that a try. Dead Link Removed
Ooops... sorry Hank for not mentioning your bushings, Since ine is a late model and you STILL don't have any for me, I forgot. Sorry.
Yes, I was aware the large 40mm front bar was hollow. Probably will go with just poly bushings with the OE swaybars. I have upgraded John Baker swaybars on my 93 and poly bushings. I am convinced just replacing the bushings on my 96 will be a big improvement and is very cost effective. Thanks Mike
