4L SOHC interchangeability | Ford Explorer Forums
vroomzoomboom
Elite Canuck STOCK SUCKS!
selkirk, manitoba
98 supercharged 347 sport
i am looking into buying a 03 sport trac that has timing chain issues. in my shed, i have the 98 SOHC motor that was in my explorer doing nothing (pulled it when i did the 5L swap). i am 98% sure the 98 SOHC motor will work in this, with changing the fuel rails, injectors, sensors, upper intake, and possibly the exhaust manifolds (which to me all is no big thing to change). is there anything i am missing, or is there more things that will have to be changed, or not.
Im doin the same thing and with both motors on the stands side by side I have come to the same conclusion . Only difference is im goin in a 02 ex from a 98.
The basic engine is the same. Yeah, you'll have to swap most of the external stuff you listed. You will find that there is a freeze out plug in the valley on 1 motor, and the other has a breather. (I cant remember which one had which.)
as in where the knock sensor is?
Yup, that would be the valley.
See the black box in the valley that the PCV hose attaches to? I've read that not all the SOHCs use the same setup.
excellent! thank you very much for posting that pic. i will have to watch for that.
All in all yes your 98 in a 03 will work. You will remove the pcv box off the 98 motor and install a freeze plug. The knock sensor, valve covers and balancer will need to be swapped over from the 03 motor. The timing cover and oil pan are the same.
