redrobster
- December 5, 2012
- Seattle WA
- 1995 4.0 ranger
Hello Gentlemen!
I am in need of some information/advise. I bought a 95 4.0 ranger 4x4 a couple months back, everything was solid except the transmission (big surprise i know). SO last weekend my brother and I swapped out the transmission for a different one.
When i bought the truck it had a 4r44e in it, I found a replacement 5r55e that would bolt right up. Both my brother and I researched the compatibility of the swap and everything looked good. fast forward a couple days, the swap is done and trans seems to have a dual personality. sometimes it will slip as it goes from 2-->3 and then when i'm going about 50mph it will jump back and forth from what i assume is 4th-->OD, making it SUPER annoying! But then i will get a couple days where the shifts are solid all the way through each gear, but there is no OD. The shifts are harder, but not something i'm not willing to live with. The Flashing OD light on the dash has come and gone here and there. I honestly look forward to seeing it, because i know i will be getting the non-slipping, no OD personality from the trans.
I would prefer to have the no OD and non-slipping trans rather than the slip and slide one i drove to work.
What are your thoughts?
