95beater
- March 5, 2004
- West Houston, TX
- 1995 XLT
With 157,000 miles on my 4r55e, it stopped shifting from 1st to 2nd and the seals on my 4405 were leaking pretty badly. It was apparent that I needed at least a transmission rebuild and some effort to address the leaks from the transfer case.
Here’s what I learned from my transmission shop (members that know better feel free to post). Some of these items are address in other posts, but I figure it would be helpful to somebody having them all in one place.
· A few weeks before the transmission blew up the o/d light was flashing and the torque converter was cycling on and off (surging) at highway speed. I suspected an electrical problem, such as the throttle position sensor (TPS), but I was too lazy/busy to check it out. According to my trans shop the TPS was bad, likely failed to control line pressure, and could have caused the trans to die. I’ve never heard of this before, but I suppose it makes sense.
· Many high-mileage 4405 x-fer cases cannot be rebuilt/made to stop leaking without replacing the case halves. According to the shop/other sources, the case bearing races/shift rail mounts wear out and cannot be fixed without significant machine work. This shop replaced the halves with machined units from this vendor: http://www.omegamachine.com/html/BW4405_rear_case_repair.html . The total cost of the rebuild (case halves, bearings, and seals) $550 installed
· A band broke in the trans and the torque converter was wasted. The new trans feels great. It’s like a new truck. According to the trans shop, the parts available today to rebuild the 4r55e eliminate many of the old drivability problems, including weak 2-3rd shifts and slow to go into D and R. It’s much smoother and fuel economy has gone up about 1-2 mpg. Trans rebuilt and installed, $1400
· Make sure the shop tests the transfer case operation in the shop and on the fly. My shop only tested the 4x4 operation in the shop, but I testing it on the way home while moving and it would not shift on the fly. The 4x4 Hi and Lo lights would flash 6 times after about 40 seconds. According to the shop, they boogered up the rear driveshaft speed sensor, which would not allow the transfer case to synchronize.
